14 years ago --- Quote Start --- I suspect its your trigger logic. You've got it setup to trigger when the NCO value is exactly all zeros. If you calculate how often that is likely to occur, you might find its infrequent. Try a different trigger source, eg. a push button, or Avalon-MM PIO signal. Cheers, Dave --- Quote End --- I thought if i had all the triggers set to don't care, it wouldn't matter what change occurred at that particular node and the signal tap would activate.
