13 years ago
True DPRAM IP
Hi
I need a true dual port RAM with 2 read and write accesses for a Stratix 4 device;
With the MegaWizard this is in fact very easy but while trying to simulate with ModelSim I see a few issues:
1) Write cycles:
While writing several cycles in a row, on the 'A' side, the cycle which follows (which WREN = '0') still causes the simulation environment to write erroneous data.
It actually writes the data which is on the D_IN bus.
This is confirmed by reading it from the other side (the 'B' side) the data is there.
Does anybody have an idea?
2)Number of clock cycles:
It seems that at least 2 cycles are required for a read operation (or 1 if there's a pipeline behind in case of continuous operation) and 1 cycle for write operation is enough.
Is there a consistent documentation for this case with timing diagrams, I have the Internal ROM RAM User Guide but there is nothing clear there.
Thanks in advance for your help
Kind regards
Thomas
