zjj
1 month agotiming violation fix
hi, I am working on the project that base on agilex 7 fpga.
project background:
- the compile setting is superior performance, sys clock is 416Mhz
- the ALM resources of the project has occupied the 70%, and has WNS -0.9 ns, TNS -29ooo ns violation.
do you have better metholodgies for timing fix?
now my work flow:
- first analyze the fit.retiming.rpt and fit.fastforward.rpt, add pipe or register according to critical chain reported in the retiming.rpt,
- then start to next compile
I doesn't analyze the fit.timing.rpt, because the endpoint is too large, and the work efficiency is low
