zjj
6 months agotiming violation fix
hi, I am working on the project that base on agilex 7 fpga. project background: the compile setting is superior performance, sys clock is 416Mhz the ALM resources of the project has occupied t...
BobC_Altera
6 months agoHi zjj
What kind of timing violations are present?
Please see these guides:
Quartus Prime Pro User Guide Design Optimization - Timing Closure
AN 903: Accelerating Timing Closure in Quartus Prime Pro provides information on rapidly resolving timing issues.
AN 584: Timing Closure Methodology for Advanced FPGA Designs
Hyperflex Architecture High-Performance Design Handbook
Here is a general work flow I use to solve timing issues:
- Fix incomplete/incorrect SDC constraints first
- Design Assistant can help in finding clock crossings that have not been set to false_path as well as other issues
- I look for the high severity items
- Resolve setup violations via retiming and pipelining
- See the guides above for QSF settings
- Let Quartus auto-fix hold violations; manually intervene only if needed
- Search for KDBs related to hold violations
- For setup violations that are greater than ~200 pS, check the path in Timing Analyzer
- In Timing Analyzer GUI, under Tasks - Macros: run Report Top Failing Paths
- Check the worst failing paths to see levels of logic and routing delay
- Can levels of logic be reduced without major impact to design? If yes, then change, if no, keep looking
- Is routing delay long relative to clock period? If yes, then see Physical Synthesis Options these setting may help
- Try multiple Fitter seeds before making RTL changes
- Use Design Space Explorer II for systematic exploration
- Consider larger RTL changes to reduce logic levels
- Do all logic functions need to run at 416 MHz? Can some regions with slower clock?
- Consider reducing clock frequency or increasing device speed grade as a last resort
Hope these notes help.
Bob
