zjj's avatar
zjj
4 months ago
timing impact
I performed compilation on two separate servers(A and B)using identical RTL source code and identical project configurations; however, the resulting timing violations differ between the two builds, with one server A has less timing violations.
Does a server with more CPU cores, higher clock speed and bigger RAM help improve project timing results?
  • Hi,
    Were they clean builds (removed all the generated files and (q)db/ folder) ? Previously generated files can have an impact on how the compiler places things, which can impact timing pretty much
    • zjj's avatar
      zjj
      Yes,  the compile env in the two serve machine is cleaning.
