Timing Constraints to Active Serial Ports
Is there a possibility to put Timing Constraints (set_input_delay, set_output_delay) to the Active Serial Ports? (AS_Data, ...)
Found a similar question in following post, but no solution.
Christian
- RichardT_altera
Hi @Elegan
I haven't try the constraints on Active Serial Ports but I think you can put the timing constraint since it is kind of IO.
You may checkout the I/O Constraints in the Timing Analyzer cookbook (link below):
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- Elegan
Hi Richard,
yes, I assume that it must be somehow possible to put timing constraints on the Active Serial Ports.
The problem is, I don't know how to address them.
I am using the altera_asmi2_qspi_interface_asmiblock to connect to a qspi-flash located at the Active Serial Ports. (Somehow a custom ASMI Paralell FPGA IP)
Unfortunately I can't find the atom_ports in Timequest. Also no results when searching for *dclk a.s.o.
The only dedicated Pins I could find were the jtag-pins (altera_reserved_tck ...).
I also searched for an .sdc of the "ASMI Parallel II Intel FPGA IP", which uses the same block to connect to the Active Serial Ports, but without success.
Christian
- SyafieqS
Nagale,
Let me check if there is any reference sdc regarding active serial and asmi
- Elegan
Thank you, at the moment I am using Quartus Prime Standard 18.0.
Maybe any improvements in newer versions?
Christian
- RichardT_altera
Can't say if it helps but using the latest Quartus version is recommended as it fix some bug in the earlier version.
Richard Tan
- Elegan
Can you clarifiy which bugs in earlier versions are related to timing constraints on the Active Serial Ports?
Unfortunately I still don't know how to exactly address them.
As there are already even Intel IP components which are addressing these ports, like the "ASMI Parallel II Intel FPGA IP", I think it has to be possible, even in earlier versions. Or how do they handle that?
Christian
