Elegan
4 years agoTiming Constraints to Active Serial Ports
Is there a possibility to put Timing Constraints (set_input_delay, set_output_delay) to the Active Serial Ports? (AS_Data, ...)
Found a similar question in following post, but no solution.
https:...
Elegan
4 years agoThank you, at the moment I am using Quartus Prime Standard 18.0.
Maybe any improvements in newer versions?
Christian
RichardT_altera
4 years agoCan't say if it helps but using the latest Quartus version is recommended as it fix some bug in the earlier version.
Richard Tan
