Timing Constraints to Active Serial Ports
Hi @Elegan
I haven't try the constraints on Active Serial Ports but I think you can put the timing constraint since it is kind of IO.
You may checkout the I/O Constraints in the Timing Analyzer cookbook (link below):
Richard Tan
Hi Richard,
yes, I assume that it must be somehow possible to put timing constraints on the Active Serial Ports.
The problem is, I don't know how to address them.
I am using the altera_asmi2_qspi_interface_asmiblock to connect to a qspi-flash located at the Active Serial Ports. (Somehow a custom ASMI Paralell FPGA IP)
Unfortunately I can't find the atom_ports in Timequest. Also no results when searching for *dclk a.s.o.
The only dedicated Pins I could find were the jtag-pins (altera_reserved_tck ...).
I also searched for an .sdc of the "ASMI Parallel II Intel FPGA IP", which uses the same block to connect to the Active Serial Ports, but without success.
Christian
