Elegan
4 years agoTiming Constraints to Active Serial Ports
Is there a possibility to put Timing Constraints (set_input_delay, set_output_delay) to the Active Serial Ports? (AS_Data, ...)
Found a similar question in following post, but no solution.
https:...
Elegan
4 years agoCan you clarifiy which bugs in earlier versions are related to timing constraints on the Active Serial Ports?
Unfortunately I still don't know how to exactly address them.
As there are already even Intel IP components which are addressing these ports, like the "ASMI Parallel II Intel FPGA IP", I think it has to be possible, even in earlier versions. Or how do they handle that?
Christian
