15 years agoTimequest results differ from Modelsim
So In Timequest I have a launch clock and a latch clock for some data.
The latch clock is about a 0.2 ns delay after launch clock. It modelsim using the slow model netlist, same as timequest, the delay between the same two clocks is 2.2 ns. Now which one is correct? It is hard to know which way to swift the clock in the pll so it can meet timing especially since it is a 200 mhz and there is a 2ns difference between timequest and modelsim. I have a tendency to trust Timequest over modelsim, because it is designed by Altera, and it knows what the launch and latch clock are. But still why is there a difference? I am using gate level simulation, at least I think so. I am using Timquest after fitting the design. Any ideas?
