15 years agoIf I understood correctly, you have two clocks output by fpga with a a phase differnece set to .2 ns then modelsim shows 2.2 ns.
I assume you can't actually measure quartus results but you have read the fitter report saying it achieved .2ns. In that case you have an issue. One suggestion is that modelsim resolution must in ps for PLLs. I believe the default is ns. Try make it ps first.
