13 years agotest bench for d flip flop
I have write a code in vhdl for d flip flop as below:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity d_ff_en is Port ( clk : in STD_LOGIC; reset : in STD_LOGIC; en : in STD_LOGIC; d : in STD_LOGIC; q : out STD_LOGIC); end d_ff_en; architecture Behavioral of d_ff_en is begin process(clk,reset) begin if(reset='1') then q<='0'; elsif(clk' event and clk='1') then if (en='1') then q<=d; end if; end if; end process; end Behavioral; and the test bench code is as below: LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.all; USE ieee.numeric_std.ALL; ENTITY dff1_tb IS END dff1_tb; ARCHITECTURE behavior OF dff1_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT d_ff_en PORT( clk : IN std_logic; reset : IN std_logic; en : IN std_logic; d : IN std_logic; q : OUT std_logic ); END COMPONENT; --Inputs signal clk : std_logic := '0'; signal reset : std_logic := '0'; signal en : std_logic := '0'; signal d : std_logic := '0'; --Outputs signal q : std_logic; -- Clock period definitions constant clk_period : time := 10ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: d_ff_en PORT MAP ( clk,reset,en,d,q); -- Clock process definitions process begin clk <= '0'; wait for 50 ns; clk <= '1'; wait for 50 ns; end process; -- Stimulus process stim_proc: process begin d<='1'; -- hold reset state for 100ms. wait for 100ms; d<='0'; wait; end process; END; There is no syntax error.But there is no output also..is test bench programme is correct.Is it necessary to correct testbench programme.Please give me the details with correction..........3 Replies
if there is a syntax error it should tell what line the error is on.
You don't stimulate 'en', so the d_ff_en will not change its status.
A tip: do not give a default value to the signals in a testbench, that way ModelSim will flag the 'X'-value (or perhaps 'U') by drawing a red trace. So you know which signals are not driven. - IMOHA
Hi there,
I wonder what for "an empty entity" is used for, in the beginning of the code?
thanks
