16 years ago
Takes too long to get address
I'm writing a simple program that reads and writes to RAM. If I want to write, I provide the starting address and a valid signal and I write to memory starting at that address until valid is deasserted. If I want to read, I provide a starting address and a readEn signal and I read from memory starting at that address until readEn is deasserted. The problem is that for some reason, the way I'm incrementing starting addresses takes an extra clock cycle and I can't figure out why.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity framestore is
	port
		clk,reset : in std_logic;
		input: in std_logic_vector(3 downto 0);
		valid: in std_logic;
		readEN: in std_logic;
		rwaddressstart: in std_logic_vector(14 downto 0);
		output : out std_logic_vector(3 downto 0);
		addressout: out std_logic_vector(14 downto 0);
		holdout: out std_logic_vector(3 downto 0)
end framestore;
architecture structure of framestore is
	signal hold: std_logic_vector(3 downto 0);
	signal address: std_logic_vector(14 downto 0);
	signal tempvalid: std_logic;
	signal tempread: std_logic;
	signal readEn_RE: boolean;
	signal valid_RE: boolean;
	component ram4bits is
	PORT
		address		: IN STD_LOGIC_VECTOR (14 DOWNTO 0);
		clock		: IN STD_LOGIC  := '1';
		data		: IN STD_LOGIC_VECTOR (3 DOWNTO 0);
		wren		: IN STD_LOGIC ;
		q		: OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
	end component;
begin
	process(clk,reset,valid,readEn)
	begin
		if(reset = '1') then
			address <= "000000000000000";
		elsif(clk'event and clk = '1') then
			tempread <= readEn;
			tempvalid <= valid;
			if(valid_RE or readEn_RE) then
				address <= rwaddressstart;
			elsif(valid = '1' or readEn = '1') then
				address <= address + '1';
			end if;
		end if;
	end process;
	store: ram4bits port map(address,clk,input,valid,hold);
	readEn_RE <= tempread <= '0' and readEn = '1';
	valid_RE <= tempvalid <= '0' and valid = '1';
	output <= hold when readEn = '1' else "0000";
	addressout <= address;
	holdout <= hold;
end structure;
The problem is that this code I think happens a cycle too late:
    --- Quote Start ---
    My input and valid appear to arrive at exactly the same time
    --- Quote End ---
    Yes. Now input is one clock cycle too early.
    In my opinion, you have added more confusion with the edge detection working on both clock edges. It doesn't seem correct the way you're doing it.
    Personally, I would proceed like this:
    - determine if all input signals are clock synchronous, otherwise provide synchronisation registers
    - sketch a timing diagram of existing input signals and expected/intended design reactions
    - check if it's feasible considering the used IP, in this case the RAM block
    - use a synchronous, single clock edge process as design basic
    The valid signal and the input are synchronous. When the valid signal arrives, that's when I want to start writing to memory. I can't just make my input one cycle delayed because my input shows up with the valid signal. I'll go back to one edge sensitivity. I just would like to figure out how I can have valid and input line up as they are, and have it still work.
    I've simplified the code a little bit to hopefully make some things happen faster/cleaner but it still misses that first value.
    library ieee;
    	port
    		input: in std_logic_vector(3 downto 0); -- the input ethernet frame
    		valid: in std_logic; --valid signal that comes with input
    		readEN: in std_logic; --high when we want to read from memory
    		rwaddressstart: in std_logic_vector(14 downto 0); --address where we want to START reading or writing
    		output : out std_logic_vector(3 downto 0); --output, has value if we're reading
    		addressout: out std_logic_vector(14 downto 0); --test signal to tell us the address
    		holdout: out std_logic_vector(3 downto 0) --test signal to tell us what's being read out of memory
    end framestore;
    	signal reg: std_logic;
    	PORT
    	end component;
    begin
    	begin
    			reg <= '0';
    			reg <= valid; --register the valid signal, don't know if this is necessary, we could just use the valid signal probably
    			if(valid = '0' and readEn ='0') then
    			elsif(valid = '1' or readEn = '1') then -- if it's not a rising edge, just start adding 1 to the address
    			end if;
    		end if;
    	end process;
    	store: ram4bits port map(address => address,clock => clk,data => input,wren => reg,q=>hold);
    	output <= hold when readEn = '1' else "0000"; --self explanatory
    	--test signals
    	holdout <= hold;
    end structure;
    dont register valid anymore.
    On a side note - the waveform you have provided just doesnt look right. Addressout is very glitchy, but it should be the same as address, which is clearly isnt, or is the addressout in the diagram another address out?
    addressout is the only address in the system, not sure why its glitchy. Taking out the register for valid resulted in my finally being able to see the first 4 bits of my input signal! Now the weird part is, it produces the first 4bits on the output for 2 clock cycles and all of the other following ones are only on it for 1! Sorry if I've been saying byte before, I forgot that everything is 4 bits wide.
    Here's a trace:
    http://img143.imageshack.us/img143/2103/37447525.png
    Thanks guys, I think I'm close
    Do you think the reason it holds the first value for 2 cycles has to do with how address is assigned and incremented? Maybe I need to assign and increment address in the first step?
    I previously mentioned, that you have also the option to register none of the RAM block input signals, because they are already registered in the RAM. This would be my preferred method to achieve a fast design reaction.
      process(clk,reset)
      begin
          next_addr <= (others => '0'); -- not actually required
          cont <= '0';
          cont <= valid OR readEn;
          next_addr <= address + '1';
        end if;
      end process;
      store: ram4bits port map(address => address,clock => clk,data => input,wren => valid,q=>hold);
      address <= next_addr WHEN cont = '1' ELSE
        rwaddressstart;
    I implemented the code you gave me:
    	signal next_address: std_logic_vector(14 downto 0);
    	signal cont: std_logic;
    	PORT
    	end component;
    begin
    	begin
    			next_address <= "000000000000000";
    			cont <= '0';
    			cont <= valid OR readEN;
    			next_address <= address + '1';
    		end if;
    	end process;
    	address <= next_address when cont = '1' else rwaddressstart;
    end structure;
    and it actually gave me the same result as what I had before (the first piece of data that gets read from memory gets read for two clock cycles).
    From a hardware level, I'm not sure I understand what this does differently. What do you mean when you say something is registered? Does that mean it's stored in a register? Does that make things slower? Why is something here not stored in a register and something in my code was? Why do I need cont for example? Why can't I just directly say address <= next_address when readEn ='1' or valid = '1'? Why do I even need the process at all? Why can't I say address <= address + '1' when etc.?
