16 years agoI implemented the code you gave me:
architecture structure of framestore is
signal hold: std_logic_vector(3 downto 0);
signal address: std_logic_vector(14 downto 0);
signal next_address: std_logic_vector(14 downto 0);
signal cont: std_logic;
component ram4bits is
PORT
address : IN STD_LOGIC_VECTOR (14 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
end component;
begin
process(clk,reset,valid,readEn)
begin
if(reset = '1') then
next_address <= "000000000000000";
cont <= '0';
elsif(clk'event and clk = '1') then
cont <= valid OR readEN;
next_address <= address + '1';
end if;
end process;
store: ram4bits port map(address,clk,input,valid,hold);
output <= hold when readEn = '1' else "0000"; --self explanatory
address <= next_address when cont = '1' else rwaddressstart;
addressout <= address;
end structure;
and it actually gave me the same result as what I had before (the first piece of data that gets read from memory gets read for two clock cycles). From a hardware level, I'm not sure I understand what this does differently. What do you mean when you say something is registered? Does that mean it's stored in a register? Does that make things slower? Why is something here not stored in a register and something in my code was? Why do I need cont for example? Why can't I just directly say address <= next_address when readEn ='1' or valid = '1'? Why do I even need the process at all? Why can't I say address <= address + '1' when etc.? Thanks
