16 years agoI've simplified the code a little bit to hopefully make some things happen faster/cleaner but it still misses that first value.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity framestore is
port
clk,reset : in std_logic;
input: in std_logic_vector(3 downto 0); -- the input ethernet frame
valid: in std_logic; --valid signal that comes with input
readEN: in std_logic; --high when we want to read from memory
rwaddressstart: in std_logic_vector(14 downto 0); --address where we want to START reading or writing
output : out std_logic_vector(3 downto 0); --output, has value if we're reading
addressout: out std_logic_vector(14 downto 0); --test signal to tell us the address
holdout: out std_logic_vector(3 downto 0) --test signal to tell us what's being read out of memory
end framestore;
architecture structure of framestore is
signal hold: std_logic_vector(3 downto 0);
signal address: std_logic_vector(14 downto 0);
signal reg: std_logic;
component ram4bits is
PORT
address : IN STD_LOGIC_VECTOR (14 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
end component;
begin
process(clk,reset,valid,readEn)
begin
if(reset = '1') then
address <= "000000000000000";
reg <= '0';
elsif(clk'event and clk = '1') then
reg <= valid; --register the valid signal, don't know if this is necessary, we could just use the valid signal probably
if(valid = '0' and readEn ='0') then
address <= rwaddressstart;
elsif(valid = '1' or readEn = '1') then -- if it's not a rising edge, just start adding 1 to the address
address <= address + '1';
end if;
end if;
end process;
store: ram4bits port map(address => address,clock => clk,data => input,wren => reg,q=>hold);
output <= hold when readEn = '1' else "0000"; --self explanatory
--test signals
addressout <= address;
holdout <= hold;
end structure;
