12 years ago
SystemVerilog Interface Synthesis Quartus 13
Quartus 13 Synthesis has the limitation that interface attributes cannot be used conveniently in a module. I am looking for a work around as this limitation does not appear in other tools.
Given a simple SV interface definition:
interface avalon_bus
    parameter ADDR_WIDTH = 16,
    parameter DATA_WIDTH = 8
    input logic clock,
    input logic reset
    // aliais/short-cut for address and data widths
    localparam AW = ADDR_WIDTH-1;
    localparam DW = DATA_WIDTH-1;
    localparam MaxAddress = 2**ADDR_WIDTH;
    logic  address;
    logic  writedata;
    logic  readdata;
    modport per (
        input clock,
        input reset,
        input address,
        input writedata,
        output readdata
endinterface
and a module that uses the interface:
module avalon_mux
    interface bus
    localparam AddrThreshold = bus.MaxAddress/2;
    logic  pipe_a, pipe_b;
    always @(posedge bus.clock) begin
        if (busin.address <= AddrThreshold) begin
            pipe_a <= bus.writedata;
        end else begin
            pipe_b <= bus.writedata;
        end
    end
endmodule
Quartus throws errors because it does not like the use of the "hierarchy separator" in most expressions. Does anyone know of a work around? Example, is there another way to express / localparam AddrThreshold = bus.MaxAddress/2 /? I have tried / const integer / and some other hacks but no luck, yet :( I have also attached an example Quartus project.
Chris
    No it didn't disappear, it was automatically moderated down by the forum's overzealous spam detection system.
    This is legal, but many not be supported by Quartus yet.
    Try a continuous assignment
    int AddrThreshold;
    assign AddrThreshold = bus.MaxAddress/2;
    I was pleasantly surprised the continuous assignment worked
    for the /AddrThreshold/ expression. But it doesn't work for the
    other uses cases, like:
    Best I can tell, I wont be able to use the parameters that are
    part of the interface. I will need to reduplicate all the parameters
    to the module:
        module avalon_mux
           MaxAddress = 16,
           DW = 16
            interface bus
            localparam AddrThreshold = MaxAddress/2;
                end else begin
                end
            end
        endmodule
    And then instantiate like:
    avalon_mux
      # (MaxAddress=bus.MaxAddress, DW = bus.DW)
       M1(bus);
    which partially defeats the purpose of using interfaces.
    Chris
