Altera_ForumHonored Contributor12 years agoSystemVerilog Interface Synthesis Quartus 13 Quartus 13 Synthesis has the limitation that interface attributes cannot be used conveniently in a module. I am looking for a work around as this limitation does not appear in other tools. Giv...Show Moreintfex_new.qar11 KB
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
