12 years agoI was pleasantly surprised the continuous assignment worked
for the /AddrThreshold/ expression. But it doesn't work for the other uses cases, like:
logic pipe_a, pipe_b;
Best I can tell, I wont be able to use the parameters that are part of the interface. I will need to reduplicate all the parameters to the module:
module avalon_mux
MaxAddress = 16,
DW = 16
interface bus
localparam AddrThreshold = MaxAddress/2;
always @(posedge bus.clock) begin
if (busin.address <= AddrThreshold) begin
pipe_a <= bus.writedata;
end else begin
pipe_b <= bus.writedata;
end
end
endmodule
And then instantiate like:
avalon_mux
# (MaxAddress=bus.MaxAddress, DW = bus.DW)
M1(bus);
which partially defeats the purpose of using interfaces. Regards, Chris
