15 years ago
SystemVerilog Extensions Error
Trying to declare a bidimensional array as input in a module.
I get the following error during synthesis
--- Quote Start ---
Error (10773): Verilog HDL error at FFT04.v(3): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
--- Quote End ---
module declaration is the following:
module test(A,Y);
input wire signed  A ;
Is this a basic HDL error or can be solved setting some Quartus feature?
Thanks in advance
    No I didn't.
    After doing it everything is fine.
    Thanks for your answer.
    This, however, means working with SystemVerilog. Hope not to loose too much in compatibility.
    one thing you'll run in to is that Quartus won't make example instantiations of SystemVerilog modules with multi-dimensional ports
    you can also set SystemVerilog mode per file instead of globally. in fact if you name the file .sv it may do this for you, if not i think there's a synthesis attribute or an assignment
    For pancake,
    can you tell me what is an "example instantiation" of a module?
    sounds like you don't use the feature, so its a non-issue :)
    if you open an HDL file and go to File > Create/Update > Create Verilog Instantiation
    Quartus will create an example instantation for the source HDL. it won't work with System Verilog multi-dimensional ports
