13 years agoSynthesis error in Quartus v12 & v11
There is an apparent synthesis error in Quartus v12, v11 and possibly other versions. I found this by adding an asynchronous preset to a register bit. When this is done that register bit is not preset to one when the async preset signal is asserted and the bit remains permanently stuck at zero even after the async signal is de-asserted. If the preset is removed from the design then the register bit will change state as expected. All the other bits in the register toggle as expected. I haven't seen this before, so it's probably a combination of things that causes it to happen. I'm seeing this in the gate level simulation; the RTL simulation functions as expected. What is the best way to bring this to Altera'a attention?
