13 years agoThe problem should be expected to occur in a reduced design as well, did you try?
qCtrl[2] will be synthesized applying "not pushback", means the polarity of this register bit is inverted, also it's D and Q lines. As a side effect, the initial state of qCtrl[2] changes to '1'. Did you notice?
