13 years ago
Synthese DDR3 controller, ArriaII GX Evaluation Board
I try to implement Qsys-System with NIOS and DDR3 on ArriaII GX Evaluation Board.
Qsys generation works with no Problem, but Quartus Analysis&Synthesis shows Errors:
Error (17044):
Illegal connection found on I/O input buffer primitive q_sys:
u0|q_sys_altmemddr_0:
altmemddr_0|q_sys_altmemddr_0_controller_phy:
q_sys_altmemddr_0_controller_phy_inst|q_sys_altmemddr_0_phy:
q_sys_altmemddr_0_phy_inst|q_sys_altmemddr_0_phy_alt_mem_phy:
q_sys_altmemddr_0_phy_alt_mem_phy_inst|q_sys_altmemddr_0_phy_alt_mem_phy_dp_io:
dpio|dqs_group[0].ddr2_with_dqsn_buf_gen.dqs_inpt_ibuf.
Source IO q_sys:u0|q_sys_altmemddr_0:altmemddr_0|q_sys_altmemddr_0_controller_phy:
q_sys_altmemddr_0_controller_phy_inst|q_sys_altmemddr_0_phy:q_sys_altmemddr_0_phy_inst|q_sys_altmemddr_0_phy_alt_mem_phy:
dpio|dqs_group[0].ddr2_with_dqsn_buf_gen.dqs_obuf also drives out to other destination than the buffer.
Error (15871):
Input port DATAIN of DDIO_IN primitive "q_sys:u0|q_sys_altmemddr_0:
q_sys_altmemddr_0_phy_alt_mem_phy_inst|q_sys_altmemddr_0_phy_alt_mem_phy_clk_reset:
clk|ddio_mimic" must come from an I/O IBUF or DELAY_CHAIN primitive
Has anyone an Idea, what can I do to find my mistake??
DDR3 Controller I copied from "a2gx125_qsys_pcie_gen1x4_11_0_1" Reference-Design(Arria II GX FPGA Development Kit).
Thank in advance
Gerhard
    Thank you for your reply.
    I did a new design with q_sys module as top Level of my design.
    I assigned Pin and and Constains and used the reference-design as reference.
    Place and Route worked now successful.
    Mybe I have difficulty to instanciate qsys generated Verilog Files in my VHDL-Design.
    In QSys generated Instantiation-Template are some stange Syntax like -->
    altmemddr_0_memory_mem_clk : inout std_logic_vector(0 downto 0) := (others => 'X');
    Error (17044):
    is the old problem for uniphy_ddr3 controller in Qsys from Quartus 11.0
