11 years ago
Simple Signed Adder is complex to understand
Hi guys, still asking beginner questions, sorry. I have this code and cant figure out what the '0' in ('0' & cin) is doing. This is what I think:
Lets say we we need to do add two to negative four:
(2)0010 + (-4)1101 where the answer is (-2)11110 (last bit '1' indicates the negative sign) so,
(a_sig(n-1) & a_sig) 00010
+ (b_sig(n-1) & b_sig) 11101
+ ('0' & cin) 00
ans 11111 (which is incorrect)
What am I getting wrong?http://www.alteraforum.com/forum//images/icons/icon8.png
Also is this signed adder actually efficient cause lots of examples suggest loads of other ways to do it and I can't figure out which one to stick to or it depends on the application?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity examples is
generic(n : integer := 4); -- number of input bits
port(a, b: in std_logic_vector(n-1 downto 0);
cin: in std_LOGIC := '0';
sum: out std_LOGIC_VECTOR(n downto 0));
end examples;
architecture add_sub of examples is
signal a_sig, b_sig: signed(n-1 downto 0);
signal sum_sig: signed(n downto 0);
begin
--convert to signed
a_sig <= signed(a);
b_sig <= signed(b);
--add
sum_sig <= (a_sig(n-1) & a_sig) + (b_sig(n-1) & b_sig) + ('0' & cin);
sum <= std_logic_vector(sum_sig);
end add_sub;
    I should say that actually all operations (add/subtract/mult/div) are basically similar for signed and unsigned (using two's complement) but some care is needed with carry bits and result width.
    But all these details are not relevant to me as the functions in libraries look after it. I will add one bit to result of +/- and for multiplying 5 bits x 5 bits the result should be 10 bits.
    The compiler tells you but not always.
    Great tip. Thanks. Is there a way I can improve and get better with VHDL other than books? There's so many interesting projects done with FPGAs but not much information when things start to get complex.
    --- Quote Start ---
    --- Quote End ---
    practice then practice. and use higher level design than lower level, don't read too much into books examples.
    By the way I should correct my thoughts on that cin:
    it does not need 4 bits but two is enough since the addition always gives it weight as lsb, and that zero is just to pretend it is signed positive.
    well I'm on the right track then I guess cause I try something new every day, so thanks for that and for the correction too. :)
    Hii guys,good work.I'm quite new to FPGA and vhdl,So I created a forum on (help..FPGA based led lighting using de2 board where d LEDs come on at night and goes off during d day using ldr as sensor.pls I need u guys to put me try.im kind of confused how to convert the analog signal from d ldr into digital form for the fpga
    --- Quote Start ---
    Oppps, thanks kaz. it's late and I'm a bit tired. So actually it is working correctly. So why is the '0' in ('0' & cin) needed for?
    --- Quote End ---
    It's a sign extension. (Actually, it is zero-extension if the word is unsigned.) You need it because:
    a) adding two n-bit vectors gives you an n+1-bit sum (a carry is generated),
    b) VHDL requires that assignments have the same length vectors on both sides of the <= (or := ), and
    c) VHDL neither auto-extends operands nor truncates results to make the vector lengths match (unlike Verilog).
    As noted in this thread, it is better to use the resize() function (from numeric_std) on signed or unsigned types than to explicitly use the '0' & foo.
    --- Quote Start ---
    --- Quote End ---
    are you sure? try multiply 8 bits value by 8 bits value onto 16 bits result
    --- Quote Start ---
    --- Quote End ---
    why? what is the resize doing anyway?
    --- Quote Start ---
    --- Quote End ---
    The multiply and divide functions in numeric_std return a result that is N+M bits long. But addition/subtraction returns a result that is as long as the largest operand.
    --- Quote Start ---
    --- Quote End ---
    The resize function does 0 extension for unsigned and sign extension for signed. It extends (or shrinks) the value the specified length.
