11 years ago --- Quote Start --- Oppps, thanks kaz. it's late and I'm a bit tired. So actually it is working correctly. So why is the '0' in ('0' & cin) needed for? --- Quote End --- It's a sign extension. (Actually, it is zero-extension if the word is unsigned.) You need it because: a) adding two n-bit vectors gives you an n+1-bit sum (a carry is generated), b) VHDL requires that assignments have the same length vectors on both sides of the <= (or := ), and c) VHDL neither auto-extends operands nor truncates results to make the vector lengths match (unlike Verilog). As noted in this thread, it is better to use the resize() function (from numeric_std) on signed or unsigned types than to explicitly use the '0' & foo.
