Serial Lite IV - Rx Simulation Issues
- 1 month ago
Thank you for the update.
For your reference, I tested the example design simulation using the default configuration and observed a runtime of approximately one hour or more, which is consistent with what you reported.
I also performed additional testing by removing one of the fast simulation parameters (
+define+IP7581SERDES_UX_SIMSPEED) and observed a longer simulation time. Based on these results, the simulation duration you are seeing appears to be expected behavior for the provided example design.Sorry for the inconvenience, and thank you for your patience.
Thanks for your input. I reinstalled Quartus 26.1 and after that both Rx and Tx do come up (Rx is up at ~91uS).
However, it took >1.5 hours to get to the point where Rx is up. And this was run on a very capable PC so although I'm now using the "Fast Simulation Libraries" - I wouldn't call it "Fast" by any means.
Can you please try to bring up the reference design simulation on your end ?
I need to know if it can do better than 1.5 hours.
- CheepinC_altera1 month ago
Thanks for your update. Glad to hear that you have managed to get the simulation up after reinstallation. Regarding the simulation duration, I am currently running the simulation to check on it. I will keep you updated on the results by end of tomorrow or Friday. Please ping me if you do not hear back from me. Thank you.
- host1 month ago
Attaching the transcript of the reference design simulation.
Maybe it'll provide some insight as to why it's taking so long.- CheepinC_altera1 month ago
