host's avatar
host
1 month ago
Serial Lite IV - Rx Simulation Issues
Hello, I'm having trouble with the RX in side when simulating the F-Tile Serial Lite IV example design.   Enviroment: - Quartus Prime Pro Edition 26.1, Windows - Questa Altera FPGA Edition-64 2...
  • CheepinC_altera's avatar
    1 month ago
    Thank you for the update.
    For your reference, I tested the example design simulation using the default configuration and observed a runtime of approximately one hour or more, which is consistent with what you reported.
    I also performed additional testing by removing one of the fast simulation parameters (+define+IP7581SERDES_UX_SIMSPEED) and observed a longer simulation time. Based on these results, the simulation duration you are seeing appears to be expected behavior for the provided example design.
    Sorry for the inconvenience, and thank you for your patience.
