16 years ago
Second opinion on timequest constraints
I was constraining an interface between a stratix II device and a digital to analog converter. Trying to close timing gave me quite a few problems. I now have a timing report free of warnings and I wanted to give a brief outline of what I have done and perhaps someone can comment and tell me if I am on the right track (as I have done one or 2 things which I hadn´t tried before).
Basically a clock from the DAC of 150MHz enters the FPGA, this clock is used to clock the rdclk pin of a DCFIFO, so the idea is that on every rising edge a new word will be clocked out to the parallel data bus of the DAC from the FIFO.
The DAC can be configured to latch the data on either the rising or falling edge of this same clock, I have elected to use the falling edge in order to give me some extra time.
To constrain the interface, I defined a virtual clock of the same frequency as the main clock coming from the DAC but inverted due to the fact that the DAC will latch the data on the bus on the falling edge.
create_clock -name {DAC_PLLLOCK} -period 6.666 -waveform { 0.000 3.333 } [get_ports {DAC_PLLLOCK}]
create_clock -name {PLLLOCK_Virtual} -period 6.666 -waveform { 3.333 6.666 }
The DAC data bus requires a setup time of 0.5ns and a hold time of 1.5ns, therefore I put in place the following set_output_delay constraints:
set_output_delay -clock { PLLLOCK_Virtual } -max 0.5 [get_ports {DAC_D*}]
set_output_delay -clock { PLLLOCK_Virtual } -min 1.5 [get_ports {DAC_D*}]
After running a timing report, on the slow model setup failed by around 6ns so I figured this was due to the fact that I was reading the data from the FIFO and placing it on the databus on the rising edge while timequest assumed that the DAC would latch it on the falling edge 3.3ns later. To overcome this I set a multicycle path between the 2 clocks as follows:
set_multicycle_path -from [get_clocks {DAC_PLLLOCK}] -to [get_clocks {PLLLOCK_Virtual}] -setup -start 2
Now after running the timing anaylsis I meet timing just about.
I would be very grateful if someone could let me know if I am on the right track with how I have constrained this interface? Is the placing of the multicycle the correct thing to do? or does it have an adverse affect that I have failed to see? Is it ok to do it with a virtual clock?
Please let me know of any other oversights on my part in constraining this interface that you may think of.
Many thanks once again for any suggestions
