Sai2403's avatar
Sai2403
1 month ago
RTL Simulation fails with: couldn't execute ip-setup-simulation: invalid argument
Hi ,
Error: Failed to run ip-setup-simulation: couldn't execute "c:\altera_pro\26.1\quartus\..\vds\bin\ip-setup-simulation": invalid argument
I have been facing this issue since morning, unable to run the simulation, yesterday it was working fine.
Even tried regenerating IP files also today, but got the same error.
Any help is appreciated.
Sai@2403
  • Hi Sai2403
    Could you help to share the design (.QAR file) so I could try to duplicate this issue from my side?
    Do you run the simulation using the RTL Simulation (also called Nativelink simulation flow)?
    Additionally, which OS are you using?
    Richard Tan
  • asdfasdf1's avatar
    asdfasdf1
    I experienced the same issue before, and running Quartus as Administrator solved it for me.
      • Sai2403's avatar
        Sai2403
        Hi RichardT_altera​ , can u suggest other method, i cant run it as admistrator , as i dont have credintials.Even if did try, but it needs to run every one as administrator, and am getting below error,though i set it to right environment variable.
        Sai@2403
