RGMII timing violation despite of false path
I'm constraining a double data rate RGMII input interface.
For reference - I'm using page 15 in this document:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an477.pdf
In my case the PHY sending the data pre-shifts the clock (so I don't have to do it myself inside the FPGA).
These are my constraints:
# Create a 125MHz clock
# virtual_source_p6: an ideal clock in the sourcing device
# P6_outclk: input clock port of the interface; 90 deg phase shifted
create_clock -name virtual_source_p6 -period 8
create_clock -name P6_outclk -period 8 -waveform { 2 6 } [get_ports {P6_outclk}]
# Set input delay based on the requirements mentioned previously
# P6_outclk is 90 deg phase shifted
# Input delay is relative to the rising and falling edges of the clock
set_input_delay -max 0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outd*}]
set_input_delay -min -0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outd*}]
set_input_delay -max 0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outd*}] -clock_fall -add_delay
set_input_delay -min -0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outd*}] -clock_fall -add_delay
set_input_delay -max 0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outen}]
set_input_delay -min -0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outen}]
set_input_delay -max 0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outen}] -clock_fall -add_delay
set_input_delay -min -0.8 -clock [get_clocks {virtual_source_p6}] [get_ports {P6_outen}] -clock_fall -add_delay
# Set false paths to remove irrelevant setup and hold analysis
set_false_path -fall_from [get_clocks {virtual_source_p6}] -rise_to [get_clocks {P6_outclk}] -setup
set_false_path -rise_from [get_clocks {virtual_source_p6}] -fall_to [get_clocks {P6_outclk}] -setup
set_false_path -fall_from [get_clocks {virtual_source_p6}] -fall_to [get_clocks {P6_outclk}] -hold
set_false_path -rise_from [get_clocks {virtual_source_p6}] -rise_to [get_clocks {P6_outclk}] -holdAlthough I set all the false paths as described in the document I keep getting timing violation between "virtual_source_p6" and "P6_outclk"
What am I doing wrong ?
- KhaiChein_Y_Intel
Can you share the design for investigation? What is the software edition (Pro/Standard) and version you are using?
KhaiY
- SKon1
I'm using Q17.1 Standard.
I'll check if the design can be shared.
- KhaiChein_Y_Intel
Sure. Please keep me updated.
KhaiY
- SKon1
How can I share the design ?
- KhaiChein_Y_Intel
You may share a non-confidential design here by clicking on the attachment symbol and attach the design.
KhaiY
- KhaiChein_Y_Intel
May I know if you have any updates?
KhaiY
