10 years ago
Request for help in VHDL troubleshooting
Hi all,
I am a new to programming of VHDL to FPGA.
Recently tried experimenting with a code from a book and during simulation, it was functioning perfectly.
However after i programmed into Altera Cyclone IV EP4CE chip, the chip is always stuck at the default state regardless of the input.
Was suspecting that the clock input is not configured properly thus i assigned the clock to Pin25 and yet it is not helping.
Hope anyone can lend a helping hand to help troubleshoot.:(:confused:
Thanks alot in advance.
The code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY Traincollision IS
PORT( reset, clock, sensor1, sensor2,
sensor3, sensor4 : IN STD_LOGIC;
switch1, switch2 : OUT STD_LOGIC;
track1, track2, track3 : OUT STD_LOGIC;
dirA, dirB : OUT STD_LOGIC_VECTOR( 1 DOWNTO 0 ));
END Traincollision;
ARCHITECTURE a OF Traincollision IS
TYPE STATE_TYPE IS ( ABout, Ain, Bin, Astop, Bstop );
SIGNAL state: STATE_TYPE;
SIGNAL sensor12, sensor13, sensor24 : STD_LOGIC_VECTOR(1 DOWNTO 0);
BEGIN
PROCESS ( reset, clock )
BEGIN
IF reset = '1' THEN
state <= ABout;
ELSIF clock'EVENT AND clock = '1' THEN
CASE state IS
WHEN ABout =>
CASE Sensor12 IS
WHEN "11" => state <= About;
WHEN "10"=> state <= Bin;
WHEN "01" => state <= Ain;
WHEN "00"=> state <= Ain;
WHEN OTHERS => state <= ABout;
END CASE;
WHEN Ain =>
CASE Sensor24 IS
WHEN "11" => state <= Ain;
WHEN "10" => state <= ABout;
WHEN "01" => state <= Bstop;
WHEN "00" => state <= ABout;
END CASE;
WHEN Bin =>
CASE Sensor13 IS
WHEN "11" => state <= Bin;
WHEN "01" => state <= Astop;
WHEN "00" => state <= About;
END CASE;
WHEN Astop =>
IF Sensor3 = '0' THEN
state <= Ain;
ELSE
state <= Astop;
END IF;
WHEN Bstop =>
IF Sensor4 = '0' THEN
state <= Bin;
ELSE
state <= Bstop;
END IF;
END CASE;
END IF;
END PROCESS;
sensor12 <= sensor1 & sensor2;
sensor13 <= sensor1 & sensor3;
sensor24 <= sensor2 & sensor4;
Track1 <='0';
WITH state SELECT
Track3 <= '1' WHEN ABout,
'1' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'1' WHEN Bstop;
WITH state SELECT
Track2 <= '0' WHEN ABout,
'0' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'0' WHEN Bstop;
WITH state SELECT
Switch1 <= '0' WHEN ABout,
'0' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'0' WHEN Bstop;
WITH state SELECT
Switch2 <= '0' WHEN ABout,
'0' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'0' WHEN Bstop;
WITH state SELECT
DirA <= "01" WHEN ABout,
"01" WHEN Ain,
"01" WHEN Bin,
"00" WHEN Astop,
"01" WHEN Bstop;
WITH state SELECT
DirB <= "01" WHEN ABout,
"01" WHEN Ain,
"01" WHEN Bin,
"01" WHEN Astop,
"00" WHEN Bstop;
END a;
    --- Quote Start ---
    Your diagram shows that the reset signal is constant '1' - why?
    --- Quote End ---
    Hi tricky, good observation..
    I have set it to active '0' instead..
    Could you show us your new code? (put it between
     and
    tags to preserve formatting)
    There seems to be some inconsistencies between the code and the signaltap screenshot.
    Also you should start with a proper reset pulse before putting some signals on the sensors, to be sure you start in a correct state.
    Hi there, sorry for the late reply.
    Was tied up with work.
    Below is the code for the program.
    I tried signaltap on it and upon toggling the sensor 1/2, i was expecting it to enter into Ain/Bin state. But yet it seem to only trigger at the first try after reset. The subsequent tries has no response. Can help advise?
    Thanks alot!
    LIBRARY IEEE;
    USE IEEE.NUMERIC_STD.all;
    ENTITY Tcontrol1 IS
    switch1, switch2, switch1a, switch2a : OUT STD_LOGIC;
    END Tcontrol1;
    ARCHITECTURE a OF Tcontrol1 IS
    BEGIN
    BEGIN
    IF reset = '0' THEN
    state <= ABout;
    CASE state IS
    WHEN ABout =>
    CASE Sensor12 IS
    END CASE;
    WHEN Ain =>
    CASE Sensor24 IS
    END CASE;
    WHEN Bin =>
    CASE Sensor13 IS
    END CASE;
    WHEN Astop =>
    state <= Ain;
    ELSE
    state <= Astop;
    END IF;
    WHEN Bstop =>
    state <= Bin;
    ELSE
    state <= Bstop;
    END IF;
    END CASE;
    END IF;
    END PROCESS;
    Track2 <='0';
    WITH state SELECT
    Track3 <= '0' WHEN ABout,
    '0' WHEN Ain,
    '0' WHEN Bin,
    '0' WHEN Astop,
    '1' WHEN Bstop;
    WITH state SELECT
    Track1 <= '0' WHEN ABout,
    '0' WHEN Ain,
    '0' WHEN Bin,
    '1' WHEN Astop,
    '0' WHEN Bstop;
    WITH state SELECT
    '0' WHEN Ain,
    '1' WHEN Bin,
    '1' WHEN Astop,
    '0' WHEN Bstop;
    WITH state SELECT
    '0' WHEN Ain,
    '1' WHEN Bin,
    '1' WHEN Astop,
    '0' WHEN Bstop;
    WITH state SELECT
    Switch1a <= '1' WHEN ABout,
    '1' WHEN Ain,
    '0' WHEN Bin,
    '0' WHEN Astop,
    '1' WHEN Bstop;
    WITH state SELECT
    Switch2a <= '1' WHEN ABout,
    '1' WHEN Ain,
    '0' WHEN Bin,
    '0' WHEN Astop,
    '1' WHEN Bstop;
    WITH state SELECT
    "01" WHEN Ain,
    "01" WHEN Bin,
    "00" WHEN Astop,
    "01" WHEN Bstop;
    WITH state SELECT
    "01" WHEN Ain,
    "01" WHEN Bin,
    "01" WHEN Astop,
    "00" WHEN Bstop;
    END a;
    have you got a testbench for this code, rather than trying to debug it on hardware (which takes much much longer)
    --- Quote Start ---
    --- Quote End ---
    Hi Tricky,
    Is this considered testbench?
    it seems You should check sensor4 )
    and
    WHEN Ain =>
    CASE Sensor24 IS
    END CASE;
    --- Quote Start ---
    and
    WHEN Ain =>
    CASE Sensor24 IS
    END CASE;
    --- Quote End ---
    Hi Alex96,
    Thanks for the pointers.
    Mind sharing the concerns with sensor4?
    --- Quote Start ---
    Hi Tricky,
    --- Quote End ---
    No - this is a waveform from a simulator. How are you producing the waveform?
    --- Quote Start ---
    Thanks alot!
    LIBRARY IEEE;
    ENTITY Tcontrol1 IS
    END Tcontrol1;
    BEGIN
    BEGIN
    IF reset = '0' THEN
    state <= ABout;
    CASE state IS
    WHEN ABout =>
    CASE Sensor12 IS
    END CASE;
    WHEN Ain =>
    CASE Sensor24 IS
    END CASE;
    WHEN Bin =>
    CASE Sensor13 IS
    END CASE;
    WHEN Astop =>
    state <= Ain;
    ELSE
    state <= Astop;
    END IF;
    WHEN Bstop =>
    state <= Bin;
    ELSE
    state <= Bstop;
    END IF;
    END CASE;
    END IF;
    END PROCESS;
    Track2 <='0';
    WITH state SELECT
    '0' WHEN Ain,
    '0' WHEN Bin,
    '0' WHEN Astop,
    '1' WHEN Bstop;
    WITH state SELECT
    '0' WHEN Ain,
    '0' WHEN Bin,
    '1' WHEN Astop,
    '0' WHEN Bstop;
    WITH state SELECT
    '0' WHEN Ain,
    '1' WHEN Bin,
    '1' WHEN Astop,
    '0' WHEN Bstop;
    WITH state SELECT
    '0' WHEN Ain,
    '1' WHEN Bin,
    '1' WHEN Astop,
    '0' WHEN Bstop;
    WITH state SELECT
    '1' WHEN Ain,
    '0' WHEN Bin,
    '0' WHEN Astop,
    '1' WHEN Bstop;
    WITH state SELECT
    '1' WHEN Ain,
    '0' WHEN Bin,
    '0' WHEN Astop,
    '1' WHEN Bstop;
    WITH state SELECT
    "01" WHEN Ain,
    "01" WHEN Bin,
    "00" WHEN Astop,
    "01" WHEN Bstop;
    WITH state SELECT
    "01" WHEN Ain,
    "01" WHEN Bin,
    "01" WHEN Astop,
    "00" WHEN Bstop;
    END a;
    --- Quote End ---
    Forgot to add on that the sensor circuitry are active low.
    When they are triggered, they goes low.
    my Advice: after source will be compiled You should open RTLViewer and StateMachineViewer. Try to make analysis step-by-step. Then compare to your waveforms.
