11 years agoRequest for help in VHDL troubleshooting
Hi all, I am a new to programming of VHDL to FPGA. Recently tried experimenting with a code from a book and during simulation, it was functioning perfectly. However after i programmed into...
11 years agoCould you show us your new code? (put it between
and tags to preserve formatting) There seems to be some inconsistencies between the code and the signaltap screenshot. Also you should start with a proper reset pulse before putting some signals on the sensors, to be sure you start in a correct state.
