maitreya_ranade
1 year agoreport_skew command fails when integrated in the timing tcl script, runs normally when ran manually
I am trying to fetch skew value with the following command: report_skew -from [get_keepers *en_fec_er*data_out*] -to [get_ports *mlvds_tx*] -npaths 1000 -detail path_only -panel_name {Report Skew...
KennyT_altera
1 year agoCan you attached your design.qar file and also your tcl scripts for investigation? What command that you use to run the tcl script as well.
maitreya_ranade
1 year agoHey @KennyTan_Altera , I am not sure I can share the qar file due to confidentiality reasons but let me check up with my team & get back to you. Apologies for the delay in response.
