Quatus 13.1 ModelSim license failure
Hi @remov_b4_flight,
Can you please help check the following?
- May I know which ModelSim edition you are using, ModelSim-Altera Starter Edition or FPGA Edition?
- Could you please verify the license environment variables. ModelSim-Altera checks for licenses in the following order:
MGLS_LICENSE_FILE --> LM_LICENSE_FILE. Kindly ensure that the variable is set correctly and points to a valid license file. - Could you also run the following command and share the output with us?
lmutil lmdiag -c <path_to_your_license_file>.This diagnostic tool can help identify whether the license file has expired, is associated with a different Host ID (MAC address), or if there is an issue communicating with the license daemon. - Additionally, please verify that the alterad vendor daemon version is up to date. You may refer to the following KDB article: https://community.altera.com/kb/knowledge-base/licensing-error-flexlm-version-of-the-vendor-daemon-is-too-old-fatal-license-err/342284.
Once you have checked the above, please feel free to let us know the results and we will be happy to assist further.
Thank you!
ZiYingE_Altera
Thanks for your reply.
Issue happened 10/27, Until 10/26 Modelsim-Altera launch normally.
I run command "lmutil lmdiag -c <license_server> -n" and watch redirected log file. related these dates.
I found 4 functions related 10/26.
"mgcvipae" v2025.06, vendor: mgcld, expiry: 26-oct-2026
"mgcvipaeaxi4" v2025.06, vendor: mgcld, expiry: 26-oct-2026
"alteramtivsim" v2025.06, vendor: mgcld, expiry: 26-oct-2026
"intelqsim" v2026.10, vendor: mgcld, expiry: 26-oct-2026
Even if the first two lines are less relevant, I believe the subsequent two lines indicate that the license has expired—what do you think?
(but local adminitrator "No linece expired" .... what???)
- ZiYingE_Altera15 days ago
Contributor
Hi DC-10,
Thank you for the information.
Based on the lmdiag output, it appears that the following features expired on 26 Oct 2026:
- alteramtivsim v2025.06, vendor: mgcld, expiry: 26-Oct-2026
- intelqsim v2026.10, vendor: mgcld, expiry: 26-Oct-2026
ModelSim-Altera requires the alteramtivsim feature to launch. This aligns with your observation that ModelSim-Altera launched successfully on 26 Oct 2026 but failed starting 27 Oct 2026.
Regarding the statement, local administrator "No license expired", could you help clarify on this?
Would it be possible to obtain a renewed license?
Thank you.
ZiYingE_Altera
- ZiYingE_Altera13 days ago
Contributor
Hi DC-10,
Just checking in to see if my previous message may have been missed.
Feel free to let us know if you have any further questions.
Thank you.
ZiYingE_Altera
- ZiYingE_Altera11 days ago
Contributor
Hi DC-10,
Good day!
Just following up to see if there are any further questions from your side.
If there are no further questions or concerns, we will set this case as close status.
Thank you.
ZiYingE_Altera
