roeekalinsky
Contributor
2 years agoIOPLL non-dedicated feedback option doesn't work correctly
In Stratix 10 and Agilex, the IOPLL supports an option for using a non-dedicated feedback path when using the normal compensation mode or source-synchronous compensation mode. However, the non-dedica...
roeekalinsky
Contributor
2 years agoHi @AqidAyman_Intel ,
I'd like to make sure that I clearly understood your response:
The internal team acknowledges that this mode doesn't actually work correctly, but they don't intend to fix it? Is that correct?
Are they simply going to document the fact that it doesn't work?
Are they going to remove this non-working optional mode from the IP and Quartus tool chain as well as the documentation?
If I do "request a patch" to satisfy Intel's internal triage processes, will they then fix it just as a point-solution patch for me only? Or will they then fold the fix into the subsequent mainline releases?
Please clarify.
-Roee
