Scarlet
2 years agoHigh-speed transmission interface at around 3 meters for FPGA to FPGA communication
Hi, I’m looking for a high-speed transmission interface at around 3 meters for FPGA to FPGA communication. My development environment: MAX10 10m08sae144c8g Quartus Prime Lite 23.1.1 Currently,...
Scarlet
2 years agoI can't believe it. Even though I added lvds_en for frame synchronization in the interface,
it still completes the reception on the rising edge of the 11th lvds_clk.
Below are my Verilog code and output results. What might I have overlooked?
module lvds_receiver ( input wire clk, input wire reset, input wire lvds_en, input wire lvds_clk, input wire lvds_data, output reg [11:0] data_out, output reg gpio_1, output reg gpio_2 ); reg [1:0] state; reg lvds_clk_prev; reg [3:0] loop = 4'h0; reg [11:0] data_reg = 0; parameter IDLE = 2'b00; parameter RX = 2'b01; parameter DONE = 2'b10; // lvds_clk_rising_edge wire lvds_clk_rising_edge = !lvds_clk_prev && lvds_clk; always @(posedge clk or negedge reset) begin if(!reset) begin state <= IDLE; end case(state) IDLE: begin if(!lvds_en) begin loop <= 4'd0; state <= RX; end end RX: begin lvds_clk_prev <= lvds_clk; // Check for rising edge of lvds_clk if (lvds_clk_rising_edge) begin data_reg <= {data_reg[10:0], lvds_data}; loop <= loop + 4'd1; gpio_2 <= ~gpio_2; end // When 12 bits are received, update data_out and reset loop if (loop == 12) begin gpio_1 <= ~gpio_1; state <= DONE; end end DONE: begin data_out <= data_reg; if(lvds_en) begin state <= IDLE; end end // default: state <= IDLE; endcase end endmodule
