obruendl's avatar
obruendl
1 year ago
RAM inference not working for initialized RAM
According to documentation RAM initialization should work in VHDL by simply adding an initialization value to the memory array.
https://www.intel.com/content/www/us/en/docs/programmable/683082/21-3/specifying-initial-memory-contents-at.html
However, In my code (see attached), this is not the case. Without initialization value (resp. with initializing all content to zero) the code infers 8kb RAM - so the syntax seems fine for RAM inference. As soon as I add any other initialization content than zeros, registers are inferred (not RAM).
I have attached my code containing both cases.
With line 109 uncommented, RAM inferrence works:
signal Mem_v : Data_t(Depth_g - 1 downto 0) := (others => (others => '0'));
With line 108 uncommented, RAM inferrence fails:
signal Mem_v : Data_t(Depth_g - 1 downto 0) := (0 => x"1234", 1 => x"5678", others => (others => '0'));
Why is RAM inference not working? What can I do to make it work?
