RAM inference not working for initialized RAM
I have even more interesting news. I fixed my memory to 16 bits and played with the exact formulations in VHDL.
Below code fails to infer RAM:
for byte in 0 to 1 loop if Wr_Be(byte) = '1' then Mem_v(to_integer(unsigned(Wr_Addr)))(byte * 8 + 7 downto byte *:= Wr_Data(byte * 8 + 7 downto byte * 8); end if; end loop;
If I just unroll the loop, RAM is inferred correctly:
if Wr_Be(0) = '1' then Mem_v(to_integer(unsigned(Wr_Addr)))(7 downto 0) := Wr_Data(7 downto 0); end if; if Wr_Be(1) = '1' then Mem_v(to_integer(unsigned(Wr_Addr)))(15 downto:= Wr_Data(15 downto 8); end if;
I feel like formulating the very same thing in a loop or unrolled should lead to the same results and if it does not, I'd call this a bug.
Unfortunately I still didn't find a language construct to cleanly work around this bug for parametrizable code - without understanding the root-cause making Quartus to behave different for the two snippets above it is difficult to find one because this (to my understanding) is not a logical issue.
Please provide suggestions how this issue can be worked around. Alternatively I could accept a confirmation of this being a bug that will be fixed in the next release of Quartus. If I know its getting fixed it'd be fine for me to just document that RAM inference for Altera works correctly starting from 25.1.
