RAM inference not working for initialized RAM
The code describes a simple-dual-port memory of 4kbit in size. Yes, some RAM is inferred but in addition to that RAM I see > 7000 registers which I would not be expected. The code really only describes a RAM.
In the meantime a contributor of Open Logic identified that RAM inference works correctly when commenting out the Byte-Enable Logic. See GitHub issue for details: https://github.com/open-logic/open-logic/issues/122
The strange thing is that the configuration of the RAM I use here does not even make use of Byte Enables. Generics are set to not use Byte-Enables - so the logic that breaks inference is unused.
I agree that the files I provided are inconsistent because I tried out a few things. I now archived the project in Quartus (QAR) in two ways:
- The failing version (including byte-enable logic): https://drive.google.com/file/d/13sTr6c7nqkbVoqz2a4C808FaXzsyirUN/view?usp=drive_link
- A version with byte-enable logic commented (which does infer RAMs correctly): https://drive.google.com/file/d/10Wbemcy09Xk6Y99eESxcZIhgwJy5aTuf/view?usp=drive_link
