Questa Starter Edition Bad License File Generated
- 4 years ago
I generated licenses until I got a working one. Most of them ended up just containing comments, but I ended up with license which actually worked after trying for a while.
Hi, have you managed to find a workaround to this issue? I tried to generate different licenses, but still get a fatal error message. Both direct license selection and environment variable set fail too.
- BalenMars4 years ago
Are you saying this is just a block of comments that have been generated?
# Intel Corporation Software and/or Intellectual Property License File
# Issued 12 April 2022
# Upgrade to these products will no longer be available after the Maintenance Expiration
# date unless licenses are renewed.
# Fixed Node License
# Primary Machine Name-Balen-PC
# Primary Machine ID-NIC ID ************
# Companion ID-NIC ID ************
# Companion ID 2-N/A
# Product License Summary:
# Questasim*-Intel® FPGA Starter Edition, 1 Seat(s)
# - Maintenance Expiration of 2023.04
# - License Expires 12-Apr-2023
# FEATURE START
# This is license file for Questasim*-Intel® FPGA Starter Edition
# Number of seat licenses is 1
# License Expires 12-Apr-2023
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 04/12/2022 - BalenMars4 years ago
OK, I finally generated a working license! It's either they fixed the bug or the it's still there corrupting the license generation every now and then.
