Quatus 13.1 ModelSim license failure
Hi @remov_b4_flight,
Can you please help check the following?
- May I know which ModelSim edition you are using, ModelSim-Altera Starter Edition or FPGA Edition?
- Could you please verify the license environment variables. ModelSim-Altera checks for licenses in the following order:
MGLS_LICENSE_FILE --> LM_LICENSE_FILE. Kindly ensure that the variable is set correctly and points to a valid license file. - Could you also run the following command and share the output with us?
lmutil lmdiag -c <path_to_your_license_file>.This diagnostic tool can help identify whether the license file has expired, is associated with a different Host ID (MAC address), or if there is an issue communicating with the license daemon. - Additionally, please verify that the alterad vendor daemon version is up to date. You may refer to the following KDB article: https://community.altera.com/kb/knowledge-base/licensing-error-flexlm-version-of-the-vendor-daemon-is-too-old-fatal-license-err/342284.
Once you have checked the above, please feel free to let us know the results and we will be happy to assist further.
Thank you!
ZiYingE_Altera
Thanks for your reply.
Issue happened 10/27, Until 10/26 Modelsim-Altera launch normally.
I run command "lmutil lmdiag -c <license_server> -n" and watch redirected log file. related these dates.
I found 4 functions related 10/26.
"mgcvipae" v2025.06, vendor: mgcld, expiry: 26-oct-2026
"mgcvipaeaxi4" v2025.06, vendor: mgcld, expiry: 26-oct-2026
"alteramtivsim" v2025.06, vendor: mgcld, expiry: 26-oct-2026
"intelqsim" v2026.10, vendor: mgcld, expiry: 26-oct-2026
Even if the first two lines are less relevant, I believe the subsequent two lines indicate that the license has expired—what do you think?
(but local adminitrator "No linece expired" .... what???)
