Quartus_syn and nested pragma not supported
I have a bunch of vhdl code which needs to be seen from Altera tools but not others, so I am using "altera translate_on/off" nested inside "pragma translate_off/on" directives:
library ieee; use ieee.std_logic_1164.all; --pragma translate_off --altera translate_on library altera_mf; -- Example Altera-specific library use altera_mf.altera_mf_components.all; --altera translate_off --pragma translate_on -- More VHDL code here
It has been working well for few years with quartus_map. But now quartus_syn has replaced it, and doesn't support nested pragma anymore which throws "unmatched altera translate/synthesis pragma found" warnings before an "unexpected end-of-file" error.
Is there a plan to restore the support of nested pragma ?
Is there a recent version of Quartus which still have the quartus_map executable ?
- ShengN_altera
Pragma is not supported in pro version check this link https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/remove-non-standard-pragmas.html
Intel® Quartus® Prime Pro Edition synthesis does not support the vhdl(verilog)_input_version pragma or the library pragma. Synthesis in other Quartus software products supports these pragmas. Remove any use of the pragmas from RTL for Intel® Quartus® Prime Pro Edition migration.
Remove the pragma and just use it with other synthesis tools. Pro version is more strict.
Sheng
- TFisc4
Hi Sheng,
Thanks you for the tip, even though it seems to contradict the documention: Intel® Quartus® Prime Pro Edition Help version 23.1 - vhdl_input_version Synthesis Directive & Intel® Quartus® Prime Pro Edition Help version 23.1 - library VHDL Synthesis Directive
Anyway in my case this is related to the "synthesis_off/on" directives. They are understood by the tool (and you can disable its support if needed), but contrary to others vendors tools and now old quartus_map, the quartus_syn doesn't support nesting it, as in my example.
Thierry
- TFisc4
For instance take this code which compiles for both quartus_map✔& quartus_syn✔:
library ieee; use ieee.std_logic_1164.all; --altera translate_off --altera translate_on library altera_mf; -- Example Altera-specific library use altera_mf.altera_mf_components.all; --altera translate_off --altera translate_on
But that one compiles only on quartus_map✔ and fails on quartus_syn
with "unexpected end-of-file" error: library ieee; use ieee.std_logic_1164.all; --pragma translate_off --altera translate_on library altera_mf; -- Example Altera-specific library use altera_mf.altera_mf_components.all; --altera translate_off --pragma translate_on
- ShengN_altera
The quartus_syn supports nesting but just not support pragma as mentioned in this document link https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/remove-non-standard-pragmas.html
Sheng
