Quartus_syn and nested pragma not supported
Pragma is not supported in pro version check this link https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/remove-non-standard-pragmas.html
Intel® Quartus® Prime Pro Edition synthesis does not support the vhdl(verilog)_input_version pragma or the library pragma. Synthesis in other Quartus software products supports these pragmas. Remove any use of the pragmas from RTL for Intel® Quartus® Prime Pro Edition migration.
Remove the pragma and just use it with other synthesis tools. Pro version is more strict.
Sheng
- TFisc41 year ago
Hi Sheng,
Thanks you for the tip, even though it seems to contradict the documention: Intel® Quartus® Prime Pro Edition Help version 23.1 - vhdl_input_version Synthesis Directive & Intel® Quartus® Prime Pro Edition Help version 23.1 - library VHDL Synthesis Directive
Anyway in my case this is related to the "synthesis_off/on" directives. They are understood by the tool (and you can disable its support if needed), but contrary to others vendors tools and now old quartus_map, the quartus_syn doesn't support nesting it, as in my example.
Thierry
