Quartus-Questa Compilation Simulation Dependency Management
Update: I tried re-ordering the files in the .qfs according to the dependencies that were implied in the error messages in the Word file attached above, but I received a very similar set of error messages, still regarding could not find the package (package_name).
I might need to access the project to further debug the issue.
Could you share your design by archiving the project (Project > Archive Project) so that I further investigate.
Richard Tan
- skim31 year ago
I appreciate your offer for help.
However, the project file is unfortunately too big, and when I tried to split it up using 7zip, the first part of the split file could not be uploaded to the forum. If you could provide a separate link for the file to be submitted to, that would be great.
If that is not possible, as I'm simply trying to implement and simulate a public project from GitHub without modifications for now, I can share the GitHub site here as well: GitHub - ece-fast-lab/ASPLOS-2025-M5: This is the respository that holds the artifacts of ASPLOS'25 -- M5: Mastering Page Migration and Memory Management for CXL-based Tiered Memory Systems
From the GitHub repo, I've been testing with the testbench file that can be found in the directory:
ASPLOS-2025-M5/hw/m5_rtl/r1bes_mmio/hardware_test_design/common/cm_sketch_sorted_cam/cm_sketch/sim/cm_sketch_tb_random.svBest regards,
