skim3
1 year agoQuartus-Questa Compilation Simulation Dependency Management
Hello, I had a question about dependency management using Quartus and Questa. For a FPGA project that I'm working on, I noticed that when I do Tools->Run Simulation->RTL Simulation, a .do file gets...
RichardT_altera
1 year agoAs I mentioned in another post, this CXL IP has specific limitations, such as not supporting SOF/POF generation. I believe the same restriction applies to simulation as well.
To my knowledge, this IP is unique in that regard. You should be able to evaluate other IPs without encountering the same limitation.
Edit: For evaluation license, simulation, compilation, & timing of CXL IP are enabled. Limitation with (no .sof/.pof generation).
Richard
