Quartus Prog Pro 20.4 with FPGA Dev Kit DK-SOC-1SSX-H-A QSPI
I am using Quartus Programmer Pro 20.4 on Windows with FPGA Development Kit DK-SOC-1SSX-H-A, and I can successfully flash a .sof file and seems to be working fine.
However, I would like to flash the QSPI with a .jic file, but I cannot find a way that does this correctly and works.
Please can you provide a step by step guide for how to flash a .jic file to the QSPI for the DK-SOC-1SSX-H-A dev kit?
If there are any hardware dip switches to be changed before/during/after the steps, please inform me of this in the step by step guide.
- WZ2
Hi there,
No harry, there is the steps:
- Change the MSEL setting to QSPI
https://www.intel.com/content/www/us/en/docs/programmable/683303/current/fpga-configuration.html
- Change the SW1, make sure the MAXV is in jtag chain:
https://www.intel.com/content/www/us/en/docs/programmable/683303/current/preparing-the-board.html
- about how to find the flash and program it, there is the refer link
That is all.
- SD2424
Thanks for instructions, however this seems to be for the MAX10 and for a .pof file.
Are these the step by step guide for programming the onboard QSPI Flash card below?
4.1. Development Kit Feature Summary (intel.com)
- QSPI Flash: 256 MB (MT25QU02GCBB8E12-0SIT)
My .jic file reference when loaded into Quartus Programmer shows up as device MT25QU02G, which is different to .pof file shown in your link below:
- WZ2
Hi there,
The .jic is stored in flash, and Max 10 use it to config the device~ If you wanna program the device by JTAG,
Could you tell me how u wanna use jic?
- SD2424
Of course I can expand on my use case. I would like on dev kit to power up, to automatically flash the firmware flashed into the QSPI Flash 256 MB (MT25QU02GCBB8E12-0SIT) into the FPGA without user intervention.
At the moment, I am flashing an .sof file with Quartus every time I power up the dev kit, which I would like to avoid doing.
- WZ2
By the way, there is the link about jic config
- WZ2
Hi there,
I am still not sure which part block you:
- Generate the jic file which supported by AS configuration.
- Use programmer, auto detect the flash and device
- Select the flash and download the jic into flash
- Make sure the MSEL is AS and than reset the board.
- WZ2
Hi there,
Sorry for the delay, because of there is the Public vacation. Could u please help me to point out which part block u or give me the screenshot of the error, I will help u to fix it~
- WZ2
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
- WZ2
Hi there,
WZ
