SD2424
3 years agoQuartus Prog Pro 20.4 with FPGA Dev Kit DK-SOC-1SSX-H-A QSPI
I am using Quartus Programmer Pro 20.4 on Windows with FPGA Development Kit DK-SOC-1SSX-H-A, and I can successfully flash a .sof file and seems to be working fine. However, I would like to flash t...
WZ2
3 years agoHi there,
I am still not sure which part block you:
- Generate the jic file which supported by AS configuration.
- Use programmer, auto detect the flash and device
- Select the flash and download the jic into flash
- Make sure the MSEL is AS and than reset the board.
