Quartus Prime Pro 20.1 install hangs
I'm trying to install Quartus Prime Pro 20.1 on a Windows 10 Pro machine and when the progress bar gets to about 55% it hangs and stops responding. CPU activity for the installer sits at 25% (4 core processor) but disk traffic drops to nothing. I've tried a disk clean up (725 GBytes free) and a reboot to no avail. I turned off all the bits I didn't want (i.e. ModelSim) so I don't know how else to simplify the issue.
TIA
Oliver
So heads up, the problem was corruption of the .tar file. I'll have to talk with the network experts, but copying the .tar to a network drive does the damage, which I could confirm by checking against the published SHA1 checksum. If I use 7zip to extract from the network version there are no complaints but the install consistently hangs.
Why the installer doesn't perform any kind of corruption check is a bit surprising in this day and age is somewhat surprising to me. Ditto, why TARs when zips would be easier for most users.
- RichardT_altera
Here are troubleshooting steps that you may check:
1. Before you download and install the software, please check that your machine System and Software Requirements are meet before installation. Ensure that your Operating System is supported. (window 10 is supported, you may double check the Quartus readme.txt at the bottom of the OS webpage)
2. Check that the disk space is sufficient for the installation of the Intel FPGA software. (I assume you have done this)
3. If you are running antivirus software, try to temporarily disable the antivirus software during the Quartus Prime software download and installation process.
4. Install with Administrator privileges.
5. Try to re-download the Quartus .tar installation package and install again. The latest Quartus Pro version is 22.4.
Richard Tan
- Oliver_I_Sedlacek
Contributor
Hmmm, download of full installer failed after 10 hours. Beer o'clock to calm down.
- Oliver_I_Sedlacek
Contributor
- Oliver_I_Sedlacek
Contributor
1. Windows 10 supports everything according to your link.
2. As per my original post 725 GBytes free space.
3. It is strictly against company IT policy to disable anti virus at any time.
4. I did try the install with 'Run as administrator'
5. I can't use Quartus 22.4 because it no longer supports the SDRAM interface IP block in the system builder.
I'm trying to download the full installer, but boy is that slow, running at only 20% of my available bandwidth. Looking like a 15 hour download
- RichardT_altera
I feel your pain with the downloads.
- Oliver_I_Sedlacek
Contributor
Giving up on Quartus Pro as I was sold a bum steer, need to pay for it. Looks like the Cyclone 10 GX wont be an option for my product.
- RichardT_altera
Have you try to install using the steps below:
https://www.intel.com/content/www/us/en/docs/programmable/683472/22-4/installing-from-tar-files.html
That's interesting. I do not aware that copying the .tar to a network drive will corrupt it. Try to untar it first and copy the files inside instead of one tar file.
Found out that copying from one machine to another has the potential to corrupt it.
- Oliver_I_Sedlacek
Contributor
Well once I knew the problem was a corrupted TAR doing a work around was simple. I've not explored alternatives but I guess I'll have to figure out how we can put a shared install on our network drive.
- RichardT_altera
I see. Other than that, do you need further help in regards to this case?
- Oliver_I_Sedlacek
Contributor
No thanks
- RichardT_altera
Good to know that. Since you have a workaround, I now transition this thread to community support.
Thank you.
Richard Tan
