Quartus Prime Pro 20.1 install hangs
- 3 years ago
So heads up, the problem was corruption of the .tar file. I'll have to talk with the network experts, but copying the .tar to a network drive does the damage, which I could confirm by checking against the published SHA1 checksum. If I use 7zip to extract from the network version there are no complaints but the install consistently hangs.
Why the installer doesn't perform any kind of corruption check is a bit surprising in this day and age is somewhat surprising to me. Ditto, why TARs when zips would be easier for most users.
Have you try to install using the steps below:
https://www.intel.com/content/www/us/en/docs/programmable/683472/22-4/installing-from-tar-files.html
That's interesting. I do not aware that copying the .tar to a network drive will corrupt it. Try to untar it first and copy the files inside instead of one tar file.
Found out that copying from one machine to another has the potential to corrupt it.
