Oliver_I_Sedlacek
Contributor
3 years agoQuartus Prime Pro 20.1 install hangs
I'm trying to install Quartus Prime Pro 20.1 on a Windows 10 Pro machine and when the progress bar gets to about 55% it hangs and stops responding. CPU activity for the installer sits at 25% (4 core ...
- 3 years ago
So heads up, the problem was corruption of the .tar file. I'll have to talk with the network experts, but copying the .tar to a network drive does the damage, which I could confirm by checking against the published SHA1 checksum. If I use 7zip to extract from the network version there are no complaints but the install consistently hangs.
Why the installer doesn't perform any kind of corruption check is a bit surprising in this day and age is somewhat surprising to me. Ditto, why TARs when zips would be easier for most users.
RichardT_altera
3 years agoI see. Other than that, do you need further help in regards to this case?
- Oliver_I_Sedlacek3 years ago
Contributor
No thanks
