Quartus Prime Lite Quitting Unexpectedly During Fitter
I am trying to integrate UART (RS-232 Serial Port) Intel FPGA IP into my project on a DE10-Nano with a Cyclone V SoC. I have followed the CVSOV UART example from the design store and I have gotten to the point to where I am trying to call the HDL created by the platform designer into my top level code. However, when i try to compile my project I get a popup saying that Quartus Quit Unexpectedly and I do not get an actual error code at all. Furthermore, when I remove the line of code which calls the HDL for the UART generated by the platform designer the code will compile.
Has anyone else seen this kind of error when trying to integrate IP into a design, or am I likely integrating the IP incorrectly? I do not know what this error means.
Thank you in advance
I was able to get the project to compile after decreasing the total memory size in the On-chip Memory IP in platform designer. I decreased the memory from about 130000 bytes to 100000 bytes and this seemed to work.
Van
- VROGE2
Van
- AnandRaj_S_Intel
Hi Van,
Try by deleting incremental_db & db folders.
Also close all the application running.
Regenerate the platform designer system and integrate on top and compile.
Also do share your design.
Anand
- VROGE2
I had already tried to delete the db folder but I had not tried to delete the incremental _db folder. I did make some changes in the platform designer in the on chip memory IP. The changes were that I changed the name of the IP's in the platform designer to follow the Max Baud Rate Cyclone V SOC Design Example and I changed the On chip memory initialization so that it does not initialize memory content. this allowed the program to compile but It does not allow for the use of the nios ii code I am using.
Here is my design as it stands now:
I altered the code in NIOS to remove some errors in the hex file, regenerated the platform designer, and re-added the platform designer qip fle and qsys file to my project. The on chip memory is still set to initialize my custom nios project and quartus still stops unexpectedly.
I can't post code at the moment because it contains items which are proprietary and I am awaiting approval to post.
Van
- VROGE2
I have gotten approval and have modified my original code to replace the proprietary sections with a counter. I still get the same error during the compilation
- AnandRaj_S_Intel
Not able to replicate the scenario with the project above.
Try by deleting incremental_db & db folders. also check original code.
Anand
- AnandRaj_S_Intel
Okay, Please click on preview report and attache it.
- VROGE2
Here it is:
Problem Details Error: Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_av_m10k_param.cpp, Line: 2085 ram_content_index < ram_content.size() Stack Trace: 0x10426: U2B_AV_M10K_PARAM_TRANSLATOR::translate_eram_bitvec + 0x5f6 (db_u2b) 0xf2cf: U2B_AV_M10K_PARAM_TRANSLATOR::convert_config_to_physical_atom + 0x12f (db_u2b) 0xcfb4d: U2B_TRANSLATOR_AV_M10K::convert + 0x9d (db_u2b) 0x349d5: FSV_U2B_POSTFIT::check_u2b_configs_for_conflicts + 0x585 (fitter_fsv) 0x396b9: FSV_U2B_POSTFIT::work + 0x139 (fitter_fsv) 0x601ca3: vpr_qi_u2b_postfit_work + 0xc3 (fitter_vpr20kmain) 0x270376: aa_flow_finalize + 0x66 (fitter_vpr20kmain) 0x26b25d: aa_flow_fit + 0x20d (fitter_vpr20kmain) 0x5735ae: VPR_QI_FACADE::vpr_qi_main + 0x6e (fitter_vpr20kmain) 0x3384e: fitapi_run_vpr + 0x7e (fitter_fitapi) 0x1fb8f: FSV_EXPERT_BASE::run_vpr + 0x13f (fitter_fsv) 0x1f64d: FSV_EXPERT_BASE::place_and_route + 0x12d (fitter_fsv) 0x1eab6: FSV_EXPERT_BASE::invoke_fitter + 0x636 (fitter_fsv) 0x1c952: fsv_execute + 0x22 (fitter_fsv) 0xe910: fmain_start + 0x900 (FITTER_FMAIN) 0x41b1: qfit_execute_fit + 0x1bd (comp_qfit_legacy_flow) 0x5384: QFIT_FRAMEWORK::execute + 0x2a0 (comp_qfit_legacy_flow) 0x267f: qfit_legacy_flow_run_legacy_fitter_flow + 0x1c7 (comp_qfit_legacy_flow) 0x14410: TclInvokeStringCommand + 0xf0 (tcl86) 0x161e2: TclNRRunCallbacks + 0x62 (tcl86) 0x17a65: TclEvalEx + 0xa65 (tcl86) 0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86) 0xa5646: Tcl_EvalFile + 0x36 (tcl86) 0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe) 0x11864: qexe_do_tcl + 0x334 (comp_qexe) 0x16755: qexe_run_tcl_option + 0x585 (comp_qexe) 0x380c3: qcu_run_tcl_option + 0x1003 (comp_qcu) 0x160aa: qexe_run + 0x39a (comp_qexe) 0x16e51: qexe_standard_main + 0xc1 (comp_qexe) 0x2233: qfit2_main + 0x73 (quartus_fit) 0x12e98: msg_main_thread + 0x18 (CCL_MSG) 0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x16660: mem_thread_wrapper + 0x70 (ccl_mem) 0x12761: msg_exe_main + 0xa1 (CCL_MSG) 0x287e: __tmainCRTStartup + 0x10e (quartus_fit) 0x17973: BaseThreadInitThunk + 0x13 (KERNEL32) 0x6a270: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus_fit Comment: None System Information Platform: windows64 OS name: Windows 10 OS version: 10.0 Quartus Prime Information Address bits: 64 Version: 18.1.0 Build: 625 Edition: Lite EditionVan
- AnandRaj_S_Intel
Hi Van,
It looks like internal error but however not replicate-able, If possible share complete design.
or
Try using Quartus Lite latest version 19.1.
We can see such error reported on Quarts v13.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd07042013_838.html
Anand
